Diferrence between guidance and monitor in Tivoli remote control
Hi All,
What is the difference between guidance and monitor in tivoli remote control session?
Also during session, we use hdsupport to login to start a remote session and it detected different user which is the local user of the controller PC, Any idea on this?
Thanks in advance,
Braian
The guidance mode is just an “enhanced” monitor view that allows you to draw instructions on the remote machines, for instance, you can highlight an area of the screen, draw a circle around an icon in the desktop, etc. It lets you guide the remote user through the different actions that may be required but you are still unable to actually control the remote machine.
I am afraid I am not familiar with hdsupport, but if you can provide more details on this, I can investigate further.
Regards,
Pati
Hi PatiN
Thanks for the info, hdsupport is an ad account for helpdesk support, for example i login to PC as braian then i started a remote session and use the hdsupport as authentication, the target PC detected braian instead of hdsupport.
Thanks,
Braian.
Hi Braian,
This works as designed. The user acceptance dialog displayed to the end user will always show the controller user (as opposed to the userid used for authentication), however, you can see the authentication details in the audited data in the application event log:
Audit the peer to peer controller user (MR0428114043)
An additional audit improvement has been implemented for this
enhancement request, which was implemented in IF0009 for
improved user acceptance auditing.
This enhancement improves auditing for P2P sessions that
require user id and password authentication against the target
system, that is those where CheckUserLogin is enabled.
In line with the previous enhancements in MR0428114043
Improved auditing for user acceptance, the session rejected
audit event was also improved to allow authentication to be
audited in sufficient detail.
To improve auditing, the following audit event was deprecated
and replaced with 9 new audit events.
Deprecated audit event
Event ID
Event Description
ibm.trc.audit.0002
Session Rejected by {0}
New audit events
Event ID
Event Description
ibm.trc.audit.005A
Authenticating user ID {0} using system logon.
Allowed groups: {1}
ibm.trc.audit.005B
Session rejected because the user ID or password is
incorrect
ibm.trc.audit.005C
Session rejected because the user is not a member
of an allowed group.
ibm.trc.audit.005D
Session rejected by {0}
ibm.trc.audit.005E
Session rejected automatically after {0} seconds
ibm.trc.audit.005F
Session rejected because the session token is invalid
ibm.trc.audit.0060
Session rejected because the session token has
expired
ibm.trc.audit.0061
Session rejected because the session token is for a
different target
ibm.trc.audit.0062
Session rejected by the server for unknown reason {0}
ibm.trc.audit.0063
Session rejected because {0} mode is not allowed
ibm.trc.audit.0064
Session rejected due to a connection error
Note : This enhancement does not modify the id that is displayed to the end
user in the user acceptance window:
  • if the session is initiated from the TRC server, it will display the id
that the controller uses to authenticate against the TRC server
  • if the session is initiated by launching the standalone controller console,
the window will display the ID the controller user uses to log on to their
local system.
Hope this helps.
Regards,
Pati
