Diferentiating licensed applications from trial versions
(imported topic written by ringelr91)
Is there a way in SUA to identify trial versions of software applications as opposed to licensed versions?
SUA will do a search on the whole drive for exe’s and also look for any installed application and then correlate that against the signature database. As far as detection goes it doesn’t care if it is licensed or not. That is what you would then use the contracts section to tie the installed applications to licensed applications. Or potentially feed the data to an Asset Management system of some sort.
Hope this answered your question.
