Customized executable not executing
(imported topic written by lmpymilk91)
My .bat isn’t firing off in the customexe folder. I have added it to the scheduled report and the archived report is being created but the .bat never launches. Any reason I might be having this issue?
The server is version 7.0.9.164
I am not sure which execution method is used by the web reports, perhaps it doesn’t support .bat… you might try:
cmd.exe /C filepath.bat
(imported comment written by lmpymilk91)
ah, good idea. I will try that this morning. I just expected it would since the last version did.
Well that didn’t work. I added the cmd.exe to the customexe folder and modified the scheduled task to run cmd.exe /c file.bat.
I watched for the cmd.exe from process explorer and never saw it launch.
Sounds like you might need someone from support to look at it with you… I don’t know why it wouldn’t be working.
(imported comment written by edmund_quah91)
Hi, I am facing the same problem.
during version 6, I have created a lot of vbscript and dos script to be run after the schedule web report. It help me to filter as well as convert it to excel.
However, after version 7, it seems like the customized executable in the web report schedule totally cannot work. Is there any solution or workaround. it will be greatly appreciated.
Edmund
Hey Edmund,
You might try contacting support…
