I am running Bigfix 10.0.1.41. I have a fixlet to create custom right-click options, but the options are not adding. The registry entry is not created. If I run the reg file manually, it adds the key. There is something about running under Bigfix. There is no error in the log file. It returns 0…
createfile until endoffile
[HKEY_CURRENT_USER\Software\BigFix\Enterprise
Console\Settings\ComputerListContextMenuExtensions\Connect to C$]
"ShellCommandRelevance"="\"explorer \\\\\" & (value of property results whose (name of property of it =
\"DNS Name\" ) of current computer as string) & \"\\c$\""
"ComputerApplicabilityRelevance"="true"
"MaxComputerSetSize"=dword:00000005
"MenuDisplayName"="&Connect to C$"
endoffile
move __createfile rightclick.reg
override wait
runas=currentuser
completion=job
hidden=true
wait cmd.exe /C regedit.exe /S rightclick.reg
delete rightclick.reg
Maybe?
No that didn’t make any difference.
I tried creating the registry entries using a reg file in the Manage Software Distribution Packages running as current user, and that didn’t work either. It completes without error, but does not add the reg keys.
I have been having issues with regedit.exe lately. try a reg import instead
[HKEY_CURRENT_USER\Software\BigFix\Enterprise Console\Settings\ComputerListContextMenuExtensions\Connect to C$]
"ShellCommandRelevance"="\"explorer \\\\\" & (value of property results whose (name of property of it = \"DNS Name\" ) of current computer as string) & \"\\c$\""
endoffile
override wait
hidden=true
runas=currentuser
wait cmd.exe /C reg import rightclick.reg
Wow!!! Thank you so much. Reg worked really well. It does not cause UAC to popup either.
