Custom 'Right-Click' Option - Copy Computer Name
(imported topic written by Aram_Eblighatian)
Having a custom ‘right-click’ option to simply copy the computer name into the clipboard (as opposed to the entire row), might be useful. Or perhaps this can be a full-fledged feature. What do people think?
(imported comment written by brolly3391)
Aram,
I have simply been writing right click tools for the things that I would normally want to paste a computer name into. It makes for less “keystrokes” at the cost of a busier context menu. If I really want to copy the computer name I just SHIFT-CTRL-P and copy from the resultant ping window.
For people wanting to keep the menu clean it might be a great advantage to be able to copy just the computer name instead of the whole line.
Cheers,
Brolly
Hey Aram,
I have heard some customers requesting this option because they want to make lists of computer names for various reasons. I suppose you could do something like this as an easy workaround:
  • Create a right-click menu item.
  • The command can be something like “cmd.exe /C echo " & computer name & " > computernamelist.txt”
That will at least create a file with a list of the computer names.
Check it!
[HKEY_CURRENT_USER\Software\BigFix\Enterprise Console\Settings\ComputerListContextMenuExtensions\FillClipBoard]
"ComputerApplicabilityRelevance"=
"true"
"MaxComputerSetSize"=dword:00000001
"MenuDisplayName"=
"&Copy Hostname"
"ShellCommandRelevance"=
"\"C:\Program Files\BigFix Enterprise\BES Console\RunQuiet.exe FillClipBoard.exe -H \" & name of current computer"
Drop these two executables in the BES Console folder (or whatever path matches the ShellCommandRelevance)
http://software.bigfix.com/download/bes/util/RunQuiet.exe
http://software.bigfix.com/download/bes/util/FillClipBoard.exe
(imported comment written by jr6591)
I get the same error with this Right-Click as I do with this one -
http://forum.bigfix.com/viewtopic.php?id=87
It looks like my attachment does not upload.
The error I receive is a Pop-Up box with this:
Not all the selected computers were able to run the selected action.
FYI … I am only selcting 1 PC at a time and I have tried different PC’s
Just wondering if anyone had any success with this? Right-Click and get the PC name would be a very nice option.
(imported comment written by Doug_Coburn)
Hi Jr,
I got this working by changing the
“ShellCommandRelevance”="“C:\Program Files\BigFix Enterprise\BES Console\RunQuiet.exe FillClipBoard.exe -H " & name of current computer”
“ShellCommandRelevance”="C:\Program Files\BigFix Enterprise\BES Console\RunQuiet.exe " & "FillClipBoard.exe -H " & name of current computer
I still must be missing something. Same error.
(imported comment written by sthull)
Hi Jr,
You’re missing a double-quote at the beginning of the ShellCommandRelevance path. You should enter it in regedit manually exactly as Doug listed above. In the .reg file it will look like:
“ShellCommandRelevance”=""C:\Program Files\…
Your’s shows the escaped double-quote is missing:
“ShellCommandRelevance”="C:\Program Files\…
Regards,
Steve
