Custom Right click menu other than computers
This is a follow on question to a sessions relevance that I posted about earlier. I have a sessions relevance that will pull back customized information about an action for our own internal reporting. As it stands now you have to select individual action ID’s and run it through the session relevance tester or the presentation debugger. I’d like to be able to right click on an action and click “Run custom report”. From what I can see on the bigfix support site, http://support.bigfix.com/labs/customright.html , it does not appear to be possible to add customized right click menus for anything OTHER than a computer.
Anyone have any experience in this, or know of a way to run customized session relevance easily from the console?
Unfortunately, I don’t believe this is feasible with current product.
That said, this sounds like a very nice idea with some interesting use cases (perhaps right-click customization options for many objects within the Console). I’d suggest filing a RFE: https://www.ibm.com/developerworks/rfe/?BRAND_ID=90
