I have an example code for customer webreport. But I am not good at HTML and session relevance.
If I want to add a column for other analyses. ex:username
example code:
a { text-decoration: none; } a:hover { color: #FF8000; font-weight: bold; text-decoration: none; } table { margin: 0; color: #222; font: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; } th { font: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; color: navy; font-weight: bold; background-color: #F2F2F2; border: 1px solid #cccccc; margin: 0; padding: 4px 10px 4px 5px; text-align: left; } td { color: #222; font: 8pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; border-bottom: 1px solid #cccccc; margin: 0; padding: 6px 20px 1px 0; } td.userinput { color: #222; font: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-weight: bold; border-bottom: 0px; margin: 0; padding: 6px 20px 1px 0; } td.errormsg { color: red; font: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-weight: bold; border-bottom: 0px; margin: 0; padding:6px 20px 1px 0; } td.msg { color: #747170; font: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-weight: bold; border-bottom: 0px; margin: 0; padding: 6px 20px 1px 0; } /*h3 { font: 10pt verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; background-color: #747170; padding: 4px 4px 4px 4px; color: white; width: 100%; }*/ table.sortable tr.wr_evenRow { background-color: #ffffff; } table.sortable tr.wr_oddRow { background-color: #dddddd; } /* Sortable tables */ table.sortable a.sortheader { color: black; text-decoration: underline; } table.sortable span.sortarrow, img { color: black; text-decoration: none; border-width: 0px; }<script type="text/javascript"> function searchComputer() { var divRes = document.getElementById('resultsDiv'); divRes.innerHTML = 'Searching...'; divRes.style.display = 'block'; computerName.value = computerName.value.toLowerCase(); var relevance = '(html "<table id=%22resultsTable%22 class=%22sortable%22><th>Application</th><th>Version</th><th>Computer</th>" & it & html "</table>") of concatenation of trs of ((if (exists first "|" of item 0 of it) then (td of preceding text of first " |" of item 0 of it) else (td of item 0 of it)) & (if (exists first "|" of item 0 of it) then (td of following text of first "| " of item 0 of it) else (td of "-")) & td of item 1 of it) of (values whose (it as lowercase contains "' + computerName.value + '") of it, name of computer of it) of results of bes properties whose (name of it contains "Installed Applications - Windows" and name of source analysis of it = "Application Information (Windows)")' var res_count = '(html "<table><tr><td class=msg>" & it as string & html " applications found</td></tr></table>") of number of (values whose (it as lowercase contains "' + computerName.value + '") of it) of results of bes properties whose (name of it contains "Installed Applications - Windows" and name of source analysis of it = "Application Information (Windows)")'; strResponse2 = EvaluateRelevance(res_count); if (strResponse2.match(' 0 applications found') == '0 applications found') { strResponse = ''; } else { strResponse = EvaluateRelevance(relevance); } document.getElementById('resultsDiv').innerHTML = strResponse2 + strResponse; sortables_init(); } </script> <table> <tr> <td class="userinput"> Enter application name: <input type="text" id="computerName" value="" style="width: 230px" /> <input type="button" value ="Generate Report" onclick="searchComputer()" /> </td> </tr> </table> <hr/> <div id = "resultsDiv"> <table> <?relevance if (not exists activations whose(active flag of it = true) of bes fixlet whose(name of it = "Application Information (Windows)")) then((html "<tr><td class=%22errormsg%22>Error: The Analysis " & link of it & html " is not enabled.</td></tr>") of bes fixlet whose(name of it = "Application Information (Windows)")) else(html " ") ?> </table> </div>
