Does anyone have a way of getting NIC information on cross platform devices?
I’m specifically looking for:
NIC Vendor
NIC Model
Driver / Firmware version
I can see there are a few ways to gather some of it using the Network Adapter inspector but it wouldn’t give me all I need and it’s also not cross platform for all parts.
I also considered using WMI for the Windows part but I don’t think that would give the Driver / Firmware version.
ETHTOOL on Linux might help but I’d need to output that to a file and then retrieve via analysis which I’m not adverse to doing, just trying to see if there is a way I can direct query using inspectors rather than deploying scripts and running them
On the Linux side, I did something similar once parsing the kernel process tables at /var/proc… I think that was in context of HP SSD or RAID firmware info, let me see what I can find but that’s at least one avenue you can explore too.
It all just shows up as files there, many of them readable text files
Got it for Unix but had to write it in a .sh to get what we needed - couldn’t see any inspector way of getting it - now just need to get the Windows one sorted which I think might need a ps1 to get it.
### Get Interface, IP, Subnet, MTU, Duplex and Speed, Driver, Version & FW Version ###
for i in $(/usr/sbin/ip a | awk -F: '/mtu/ {print $2}' | grep -v " lo")
do echo -e "Interface: $i ..."
echo -e "IP/Subnet: \c"; /usr/sbin/ip a s dev $i | awk '/inet/ {print $2}' &&
echo -e "MTU: \c"; /usr/sbin/ip a s dev $i | awk '/mtu/ {print $5}' &&
echo -e "MACADDR: \c" ; /usr/sbin/ip a s dev $i | awk '/link/ {print $2}' &&
/usr/sbin/ethtool $i | awk '/Speed/ || /Duplex/' | tr -d '\11' &&
/usr/sbin/ethtool -i $i | head -3 ; echo -e ""
done > /var/tmp/sdnetipdata.out
