Creating a Custom Task - Copy paste of relevance does not work
(imported topic written by sureshhan91)
We are newbies to the Relevance scripting. We are trying to create some Custom Tasks where we would like to use some relevance checks from existing fixlets. Though we are able to select the relevance code from the existing fixlet (Ctrl-C or Copy) we are unable to paste this into notepad / Relevance debugger.
We also tried creating a custom copy of the fixlet and do a Copy of the relevance code. No luck in pasting the relevance code.
Any pointers.
Thx
(imported comment written by FITZPAW91)
Hi sureshhan
I had this same problem and I resolved by by
  1. Edit the Custom Task, then cut from there. If that doesn’t work
  2. Export the Custom Task and grab the relevance from the text document.
I think this might have something to do with Terminal Services, but it used to work for me before.
Regards
William
Try this post: http://forum.bigfix.com/viewtopic.php?id=110
We think this is fixed in 8.0. Also see: http://forum.bigfix.com/viewtopic.php?id=4913
