Computers with System Standby enabled:
(imported topic written by emock91)
I have 11 conmputers that are stuck with Standby enabled … I re-deployed the policy with no standby selected and I can’t seem to get rid of the Standby mode … ???
Any help please
Hi emock,
Are you disabling standby using the wizard in the Power Management site? If so, are you doing this for the “default user” or the “current user”?
(imported comment written by emock91)
Current user …
Is there a way to tell what power profile is running on a particular workstation ?
The status also shows Not Relevant when I tun the task
Hi emock,
Are you unchecking the option or setting the value to 0? Unchecking the option means it won’t change the value, but setting it to 0 will disable Standby:
http://support.bigfix.com/images/miscscreenshots/powerprofile-screenshot.jpg
To tell what power profile the computers are using, select
“View Power Settings”
from the
Power Tracking Information
dashboard OR go to the analyses tab and select the “Windows Power Options Information” analysis:
http://support.bigfix.com/images/miscscreenshots/powersettings-screenshot.jpg
That worked . Thanks
