We are using Bigfix 9.5.5.193 and most of the computer have computer name , id and other properties as not reported . I looked into the UDP communication in client logs and the communication was successful . I also did a force refresh of the client and still the properties are not updated.
BESAdmin is configured to run everyday and remove the expired computers older than 15 days.
Client Logs
At 10:39:43 -0600 -
ForceRefresh command received. Version difference, gathering action site.
At 10:39:44 -0600 - actionsite (http://xxxxx:52311/cgi-bin/bfgather.exe/actionsite)
Downloaded ‘http://127.0.0.1:52311/bfmirror/bfsites/manydirlists_3/__xxxxx’ as '__TempUpdateFilename’
At 10:39:45 -0600 - actionsite (http://xxxx:52311/cgi-bin/bfgather.exe/actionsite)
Gather::SyncSiteByFile merging files - count: 2
At 10:39:46 -0600 -
Successful Synchronization with site ‘actionsite’ (version 62739) - 'http://xxxx:52311/cgi-bin/bfgather.exe/actionsite’
Gathering all operator/mailbox sites.
At 10:39:47 -0600 -
Successful Synchronization with site ‘mailboxsite’ (version 1) - 'http://xxx:52311/cgi-bin/bfgather.exe/mailboxsite12228536’
Report posted successfully
At 10:39:47 -0600 - actionsite (http://xxxxxx:52311/cgi-bin/bfgather.exe/actionsite)
Relevant - (fixlet:1757321)
At 10:39:47 -0600 -
Full Report posted successfully
At 09:24:13 -0600 -
GatherActionMV command received. Version up to date, gathering skipped.
At 09:25:31 -0600 -
Update : I even tried removing the client from the database . Even when it reported back the properties are notreported.
The Client Version is also 9.5.5.193
Found the issue : the analysis not executing on all the servers as the below relevance is evaluating to false, so not all the computers are getting applicable.
(if exists property “in proxy agent context” then ( not in proxy agent context ) else true)
