Client machine not reporting nearby realy
Hi folks,
We have multiple sites in our infra and we put a local realy on every sites.
we are facing a problem very frequently is this :- some time client machine (endpoint)
report to correct realy (local relay), but most of the time client report to primary server and very often report to top level relay.
Please suggest.
Thanks in advance.
I recommend setting the following settings on your Top Level Relays and your Server (FailoverRelayList has no effect on the server, so don’t set it on the server itself).
_BESRelay_Selection_AutoSelectableRelay
_BESClient_RelaySelect_FailoverRelayList
For a description of the setting options, and other available settings visit here.
