Checking for missing values while using tuple in relevance
Relevance:
exists file “/opt/sni/unix/etc/bladeinfo” and (tuple string item 7 of concatenation ", " of substrings separated by “:” of line whose ( it contains “HS21”) of file “/opt/sni/unix/etc/bladeinfo” as version < ")
TRUE Sample:
rdcbc001mm:02:uxprd105:HS21:1.07:1.04:1.11:1.4.11.38e:enabled
FALSE Sample:
rdcbc001mm:02:uxprd105:HS21:1.07:1.04:1.11:1.4.11.43:enabled
Need these to also be FALSE? How can I code relevance for these to be FALSE?
rdcbc001mm:02:uxprd105:HS21:1.07:1.04:1.11::
rdcbc001mm:02:uxprd105:HS21:1.07:1.04:1.11:Not Available:enabled
I will get TRUE for the first and FALSE for the second
But how would I check for NO Value or “Not Available” to get a false answer?
Any help would be appreciated…
This might work, please give it a try.
exists file “/opt/sni/unix/etc/bladeinfo” and (if (exists it as version) then (it as version < ") else (false) ) of (tuple string item 7 of concatenation ", " of substrings separated by “:” of line whose ( it contains “HS21”) of file “/opt/sni/unix/etc/bladeinfo”)
Lee Wei
Not quite… I get a true answer, expecting a false
rdcbc001mm:11:lnxlab28:HS21:1.02:1.00:1.04::
What does your complete file look like?
If this is the only line, it will work.
However, if there are other “HS21” lines in the file, then your original construct does not work after splitting and combining the elements together.
The sample above is the only line in the file
Jeff,
We must be missing something obvious.
I cannot reconcile the behavior that you are seeing.
You have an extra : after 1:02 that’s making your result false, mine is true, but needs to return false for the lack of a value in the 7th position
Q: lines of file “/opt/sni/unix/etc/bladeinfo”
A: cbcbc003mm:04:uxlab023:HS21:1.21:1.08:1.23::
T: 160
Q: tuple string item 7 of concatenation ", " of substrings separated by “:” of line whose ( it contains “HS21”) of file “/opt/sni/unix/etc/bladeinfo”
A:
T: 295
Notice an empty or null value
Q: exists file “/opt/sni/unix/etc/bladeinfo” and (if (exists it as version) then (it as version < ") else (false) ) of (tuple string item 7 of concatenation ", " of substrings separated by “:” of line whose ( it contains “HS21”) of file “/opt/sni/unix/etc/bladeinfo”)
A: True
T: 8137
The above needs to be false, not true
Another option would be to force a value into position 7 when the bladeinfo file is created such as “N/A”.
Does that help? If the value of position 7 is “N/A” return false, else compare as version
I think the problem is that item 7 of your custom tuple exists, its just that its an empty string. In windows, if you try to cast that as a version it not work (making that if statement false, cause the whole expresssion to work as you want it to)
In unix system however i think you are allowed to make empty strings versions in relevance (since unix versions are more flexable than windows). You might want to change your expression to check that the length of the tuple string, rather than if it can be caste into a version:
Q: (if (length of it > 0) then (it as version < ") else (false) ) of (tuple string item 7 of concatenation ", " of substrings separated by “:” of “rdcbc001mm:11:lnxlab28:HS21:1.02:1.00:1.04::”)
A: False
T: 0.143 ms
A: False
(imported comment written by MarkA.Stevens)
I have to admit that I am partial to regular expressions rather than using concatentations and first/last of “:” So that said, here is my suggestion for
TRUE Sample:
Q: if ( exists (matches (regex "
:+):frowning:
+):frowning:
+):frowning:
+):frowning:
+):frowning:
+):frowning:
+):frowning:
+):(.*)$") of (lines of file “/opt/sni/unix/etc/bladeinfo” as string)) whose (parenthesized part 8 of it as version < ")) then (true) else (false)
A: True
T: 658
IHTH … Mark
