Catagory entry issue
Hello,
Has anyone run into an issue where when creating web reports in version 7 - when you add text to the “Catagory” field - the report shows no catagory when saved? After creation of the report - you can then edit, add the catagory again - and then it will save with the report. Have found this issue to be across different versions of IE and with different users.
Thanks.
Mike
