As a matter of fact, yes, but in my use case I only looked into UUID IF the Serial Numbers are not there (apparently, SPARC virtualization LDOM/IODOM, etc “inherit” Serial Numbers from the hypevisor, so for those I opted to use UUID as an unique identifier). So as you can imagine it all depends on the architecture:
on X86 architecture [Relevance to check: (name of it starts with “SunOS” and architecture of it = “amd64”) of operating system]:
- if the machine is container [Relevance to check: (exist file “/etc/zones/index” whose (exists lines whose (not (it starts with “#”) and (it as lowercase starts with (computer name as lowercase & “:”))) of it)) or (exist zone (computer name) | false)] then the info should be in this json file and just a matter of extracting it: value of key “uuid” of elements of json of file “/var/share/zones/index.json”
- if the machine is physical [Relevance to check - pretty much if it is NOT a container] then the info should be available with default relevance inspectors: uuid of hardware but again, I didn’t really bother to look into that too much.
on SPARC architecture [Relevance to check: (name of it starts with “SunOS” and architecture of it = “sparcv9”) of operating system]:
- if the machine is container [Relevance to check: (exist file “/etc/zones/index” whose (exists lines whose (not (it starts with “#”) and (it as lowercase starts with (computer name as lowercase & “:”))) of it)) or (exist zone (computer name) | false)] then the info should be in this json file and just a matter of extracting it: value of key “uuid” of elements of json of file "/var/share/zones/index.json"
OLDER versions have /etc/zones/index instead of the JSON file, so might be worth taking a look at that file too
