I am trying to get a system partition created on Windows 8.1 images that do not have a partition for BitLocker.
This is the command I have in a batch script file: bdeHdCfg.exe -target c: shrink -size 350 -quiet
I can run it manually successfully, however I cannot get BigFix to run it successfully. It gives me an exit code of 1. I can even run it using an admin MS SysInternals PSTools which is a command prompt that runs as system and it works.
Try adding action uses wow64 redirection false
to your actionscript before running the batch file.
Or, as a test, use the PSTools to launch a 32-bit command prompt via psexec -s c:\windows\syswow64\cmd.exe
and then see what (if anything!) happens when bdeHdCfg.exe is run in a 32-bit environment.
edit: probably nothing happens. I can see there is a 64-bit bdeHdCfg.exe, but no 32-bit equivalent is present. So I think disabling the 32-bit redirection in the action script is the way to go.
Update:
Turns out I had changed the size in the script to 300 MB instead 350 MB which was the required minimum. Once I fixed this, combined with “action uses wow64 redirection false” I was able to get it working. Thanks for your help Jason!!
