BigFix session relevance editor - connectivity with secure web reports
(imported topic written by Anuj_Attree91)
How can we configure BigFix session relevance tester with secured BigFix webreports?
Please suggest.
Anuj
Anuj,
The Session Relevance Tester will support secured Web Reports in general.
However, it is likely that your HTTPS certificate is not signed by a trusted authority, a so called private certificate.
The application is returning a security error.
I fixed this in a newer version that I have yet to publish. The new version will ignore the security warning.
I will send you a private message with a link to download the new version. You can try to see if it fixes your problem, and please let us know the outcome.
Lee Wei
Anuj,
Your email address bounced and does not work.
Can you please contact me instead.
Lee Wei
(imported comment written by Anuj_Attree91)
Hi Lee,
I installed the personal certificate as Trusted root certification authority and it worked like charm.
Thanks for your valuable support.
Thanks,
Anuj
Good man, thanks for letting me know.
(imported comment written by nagaraj.s)
hi lee
i have some query in tivoli endpoint manager
  1. can we take system hard disk value like 500GB, 250GB. send relevance
  2. in web report we have more DNS server IP so I need separate column like DNS IP is 192.169.1.0,192.169.2.0,192.169.3.0 so i need DNS server 1 and DNS server 2 column wise in web report … send relevance
3)RAM value taking from BIOS or WINDOWS OS
The relevance for RAM and Hard Disk are already found in analyses provided by IBM, it is just a matter of displaying the results in WebReports.
This analysis also has RAM:
http://bigfix.me/analysis/details/2994635
This analysis also has hard drive info:
http://bigfix.me/analysis/details/2994572
Also, you should post this request to a new topic / thread.
