BigFix Relay installation problems
(imported topic written by savramescu91)
Hello,
I’m having trouble installing the Relay on a server. I’ve installed the Client in E:\Program Files\BigFix Enterprise\BES Client. When I try to activate the Relay from the Console nothing happens. If I try to install it manually the folder C:\Program Files\BigFix Enterprise\BES Relay folder is created but there’s nothing in it. Also there are no registry keys being written either. If I run BES Client Remove I see the Client ok, but the Relay has Unknown version.
Any tips on this will be greatly appreciated.
Thanks & Regards,
Stefan
Hey Stefan,
I am not sure… You probably want to contact support so they can investigate with you…
