Hi Team,
I am Creating a offline Media. The Bigfix Server is not on default port. But whenever the relaydownloader downloads it takes default port and the action fails.
Can someone point if i am going wrong. Not sure of any configs of relay downloader.
At first glance, this seems like a bug to me. If you haven’t done so already, I’d recommend contacting support to get this addressed.
that port should be configured at bare metal server start time when the environment is set.
Could you please check the logs of your bare metal server (default location is C:\TPMfOS Files\log\vm.trc) to see if you can find the trace:
Initializing TEM Relay port to …
Thanks.
When we do the Normal Bigfix Baremetal imaging Network book . The Relay downloader connects on 443 port . I validated this on targets on different location . The Port <52311> is only been taken at the time of Deployment Media.
Thanks.
