Bigfix "domains" missing after installation
(imported topic written by JRigas)
Hey,
I installed a new TEM server, and everything worked perfectly.
All the sites and “domains” (like patch mgmt, sys lifecycle, …) were coming in after a while.
Then I ran some nmap scans, and suddenly only "all content’ and “system lifecycle” are the only buttons left in the menu.
I checked the “add/remove buttons” option, and the only ones that are available are the ones I mentioned.
I also ran the diagnostics tool, and everything is showing green. Even the log file has no mention of something weird happening.
Did I somehow lose all my data?
Argh, nevermind. I cleared cache and set cache to “Always load data from database” and got everything back.
Phew, had a small nervous breakdown :slight_smile:
