Any idea why it’s picking up the D drive? Do you install other programs there? Seems like there might be a bigger problem.
In any case, if we just assume the question is about customizing BigFix Console installation path… if you run the console installer from command line with a /? switch, it’ll give you the following box:
Perhaps you could play around with passing the INSTALLDIR standard MsiExec parameter via the /V flag.
