BigFix Compliance: Updated DISA STIG Checklist for Red Hat Enterprise Linux 9, published 2026-10-29
Product:
BigFix Compliance
Title:
Security Benchmark:
Red Hat Enterprise Linux 9 STIG SCAP Benchmark, V2R10
Published Sites:
DISA STIG Checklist for RHEL 9, site version 12
(The site version is provided for air-gap customers.)
Details:
Total New Fixlets: 3
Total Updated Fixlets: 21
Total Deleted Fixlets: 3
Total Fixlets in Site: 435
New Fixlets:
RHEL 9 must audit all uses of the useradd command.
RHEL 9 must be able to initiate directly a session lock for all connection types using smart card when the smart card is removed.
RHEL 9 must implement DoW-approved encryption in the OpenSSL package.
Updated Fixlets:
RHEL 9 must require authentication upon booting into single-user and maintenance modes.
RHEL 9 must check the GPG signature of software packages originating from external software repositories before installation.
RHEL 9 must check the GPG signature of locally installed software packages before installation.
RHEL 9 must have GPG signature verification enabled for all software repositories.
RHEL 9 must remove all software components after updated versions have been installed.
The RHEL 9 file system automounter must be disabled.
RHEL 9 must enable the Standard Mandatory DoW Notice and Consent Banner before granting local or remote access to the system via a graphical user logon.
RHEL 9 user account passwords for new users or password changes must have a 180-day maximum password lifetime restriction in /etc/login.defs.
RHEL 9 user account passwords must have a 180-day maximum password lifetime restriction.
RHEL 9 system accounts must not have an interactive login shell.
RHEL 9 must be configured so that user and group account administration utilities are configured to store only encrypted representations of passwords.
RHEL 9 must require reauthentication when using the "sudo" command.
RHEL 9 must require authentication to access emergency mode.
RHEL 9 must require authentication to access single-user mode.
RHEL 9 must have the AIDE package installed.
RHEL 9 must use cron logging.
RHEL 9 must take action when allocated audit record storage volume reaches 95 percent of the audit record storage capacity.
RHEL 9 must allow only the information system security manager (ISSM) (or individuals or roles appointed by the ISSM) to select which auditable events are to be audited.
RHEL 9 must audit all uses of the gpasswd command.
RHEL 9 must audit all uses of the passwd command.
RHEL 9 must generate audit records for all account creations, modifications, disabling, and termination events that affect /etc/security/opasswd.
Deleted Fixlets:
RHEL 9 must not have the ypserv package installed.
RHEL 9 must not have the quagga package installed.
RHEL 9 must implement a FIPS 140-3-compliant systemwide cryptographic policy.
Additional details:
Both analysis and remediation checks are included.
Some of the checks allow you to use the parameterized setting to enable customization for compliance evaluation. Note that parameterization and remediation actions require the creation of a custom site.
Improved a few checks by adding the pending restart feature to them. The pending restart feature works in the following ways:
The action results will show “Pending Restart” instead of “Fixed” for those checks which require OS reboot.
The check will show relevant for those endpoints until they are rebooted.
Post reboot of the endpoint the action results will show as “Fixed” and the check will be compliant.
Action to take:
To subscribe to the above site, you can use the License Overview Dashboard to enable and gather the site. Note that you must be entitled to the BigFix Compliance product and you must be using BigFix version 10.0.0 and later.
If you use custom sites, update your custom sites accordingly to use the latest content. You can synchronize your content by using the Synchronize Custom Checks wizard. For more information, see Using the Synchronize Custom Checks wizard
More information:
To know more about the BigFix Compliance SCM checklists, please see the following resources:
BigFix Forum:
Compliance (Release Announcements)
This category is used by HCL to announce new releases for BigFix Compliance.
BigFix Compliance SCM Checklists:
SCM Checklists
This category is the central reference for all SCM Checklists supported by BigFix Compliance. It covers the complete list of active checklists across all supported frameworks and platforms, including CIS, DISA STIG, PCI DSS, NIST, and more, along with site name, version details, and supported OS versions.
We hope you find this latest release of SCM content useful and effective. Thank you!
– The BigFix Compliance team
