I see from the documentation that it is possible to install BigFix and ILMT using non-root user, but the server will not be registered as a system service and it will not be possible to upgrade later using a fixlet.
Installing the server using non-root and manually register the server as a system service and performing manually upgrades without fixlets will solve these limitations?
Is it possible to start the server using non-root.
Is this a supported solution or might this cause unwanted scenarios? In other words, using non-root is a bad thing?
The “Bigfix server” on Linux doesn’t support non-root installation. Non-root installation is supported only on the WebReports and the Webui components.
No problem, I have noticed I wrote “non-root intallation is supported only om WebReports…” Actually the Webreports server must be installed as root, but we allow the capability to run the service as non-root user. This is an option available at installation time. Regards Fabio
