Hello
We are running a Windows 2019 box with SQL installed locally and BFI 10.0.10 installed. Over the weekend the imports failed and in the import lock SQL Error Code 1222 SQL State S00056 Lock request time out period exceeded. WE have 90K clients reporting, have the scans and imports split up. Normally the import takes 1 hours 15 minutes to run. Is there a setting I should modify the change the default lock setting?
