I have created this analysis which checks the registry for the Monthly Cumulative patch for each of the various OS (Server 2008 - Server 2019) and confirms Install Status. The resulting data is correct but analysis is slow enough that for some reporting servers it times out and you have to send a refresh to get a result. Can someone help me improve the performance of this analysis?
(if (exists keys whose ((value “InstallName” of it as string contains “KB4556860”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556854”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556836”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556843”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556840”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556852”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556846”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556853”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4556813”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) OR (exists keys whose ((value “InstallName” of it as string contains “KB4551853”) AND (value “CurrentState” of it as string contains “112”)) of keys “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages” of (x64 registries; x32 registries)) then “Installed” else “Not Installed” )
