Hello everyone, we have implemented a series of task that run some rest api commands, gathers the info and then run a perl script to run specific commands.
the task, api comands and perl script executes correctly AS LONG AS there is no other perl process running in the box. when there is another task running, the other task will go into evaluating state for as long as the other perl process is running.
if I kill the running perl process the other process will immediately kick in.
We have perl process that need to run for a couple of hours at least and the chances of having another task running in the same box are very high…
Any ideas on how to make the evaluating status to go away or make the task to be able to run in parallel?
Thanks a lot for any help
thanks.
