Advice needed in using the Enable Privacy feature from BigFix Remote Control v10
Hello All,
Our environment endpoints are updated to v10 Remote Control which provides a stable release of a feature called ENABLE PRIVACY.
We want it to be automatically enabled whenever someone takes remote control of that device. Hence, needed advice in doing that.
Thanks in Advance.
Aditya Porwal
Hello adityaporwal,
If you have a RC server you need to set the following policies:
  • Set target locked = yes
  • Display screen on locked target = no
if you want prevent the Privacy Mode from being disabled during a session from the Controller you can set:
  • Allow input lock = no
while for P2P sessions (no RC server installed) you need to manually set the following properties:
  • EnablePrivacy = yes
  • AllowPrivacy = no
Regards
Related:
