Adding separators and filtering headers
(imported topic written by jpeppers91)
I have a block of text in a text file where I want to remove the top line and add semi-colon separators to it or filter it in the console where it doesn’t display the top line and add the separators.
Any ideas?
Description HotFixID InstalledOn Remove
Update ; 982861; 11/30/2012
Update ;KB958830 ;10/26/2011
Update ;KB971033 ;10/26/2011
(imported comment written by jpeppers91)
Bump
Anyone?
(imported comment written by SteveHull)
If the format is consistent on each line and the items are separated by a space, you can use:
q: (concatenation ";" of substrings separated by " " of it) of lines whose (line number of it > 1) of file "C:\temp\file.txt"
A: Update;982861;11/30/2012
A: Update;KB958830;10/26/2011
A: Update;KB971033;10/26/2011
On the server side, you can filter by getting property results that don’t contain “HotFixID”
Regards, Steve
My output comes out like this
I was basically trying to find a way to clean up the data where I can present it better by using delimiters, instead of 1 it fills it in between each category
Update;;;;;;;;;;;KB958830;;;10/26/2011;;;
Update;;;;;;;;;;;KB971033;;;10/26/2011;;;
Security;Update;;KB2425227;;10/26/2011;;;
Security;Update;;KB2479943;;10/26/2011;;;
Update;;;;;;;;;;;KB2484033;;10/26/2011;;;
Update;;;;;;;;;;;KB2488113;;10/26/2011;;;
Security;Update;;KB2491683;;10/26/2011;;;
Update;;;;;;;;;;;KB2492386;;10/26/2011;;;
Security;Update;;KB2503665;;10/26/2011;;;
Try this:
q: ((if length of parenthesized part 2 of it > 1 then parenthesized part 1 of it & parenthesized part 2 of it else parenthesized part 1 of it) & "|" & parenthesized part 3 of it & "|" & parenthesized part 4 of it) of (first matches (regex "(\w+)(\s\w+)?\s\s*(\w+)\s\s*(\d*\/\d*\/\d*)") of (it as string)) of lines whose (line number of it > 1) of file "C:\temp\file.txt"
A: Update|KB958830|10/26/2011
A: Update|KB971033|10/26/2011
A: Security Update|KB2425227|10/26/2011
And if you don’t want to use regex:
Collpase or remove white space in a text string without using regex
