Hi All,
Please I am having an issue getting the below Action script to achieve the desired goal of obtaining {parameter “ZONE”} from the Target_List.txt file
When I run it, I get the outcome in the attached file, which only correctly identifies the 1st parameter (ID) but does not identify the 2nd parameter (ZONE)
The content of the Target_List.txt file is as below:
7634,SD345
3601,DQ246
parameter "ID" = "{value of setting "Store Number" of client}"
parameter "ZONE" = "{if (exists file "C:\support\Target_List.txt") then (if (exists line containing "(parameter "ID")" of file "C:\support\Target_List.txt") then (following text of last "," of lines containing "(parameter "ID")" of file "C:\support\Target_List.txt") else ("AA0 0AA")) else ("AA0 0AA")}"
Most grateful for any assistance/steer on this.
Thank you.
