9.5.4 to 9.5.5 Upgrade document required
Hi Team,
If any one has the Upgrade document from Bigfix 9.5.4 to 9.5.5 could you please share me.
Thanks a lot
Have you checked out:
https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli%20Endpoint%20Manager/page/IBM%20BigFix%209.5.5%20Release%20Notes
https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli%20Endpoint%20Manager/page/Upgrading
https://www.ibm.com/support/knowledgecenter/SSQL82_9.5.0/com.ibm.bigfix.doc/Platform/Installation/c_upgrading1.html
http://www-01.ibm.com/support/docview.wss?uid=swg21505920
The upgrade process is pretty much always the same, but there may be some minor differences depending on your environment. My documented steps are pretty much the same as the above links with specific notes for my environment.
Best thing to do is set up your test environment the same as your production and then document the upgrade steps. There are also specific tasks you might need depending on the modules you have installed.
If there is one thing that IBM has done pretty well, it is to document this process.
Martin
Hi Martin,
I am going to upgrade the Infra first time in our production environment.
I have seen last time how my Colleague in onsite upgraded the Infra.but i need the Up gradation document if you have.
Please share me if you have or any one of your colleague done in their test or prod infra.Thanks
Hi All,
Does any one documented Upgrading Bigfix Infrastructure?
If so Please share me the document.Thanks…
Is there something specific that you are looking for that was not provided in the links referenced already in post 2? (9.5.4 to 9.5.5 Upgrade document required)
